5. Host software#
The Joulescope host software runs on a host computer and communicates with the Joulescope JS220 instrument over USB 2.0 high-speed.
5.1. Joulescope User Interface#
The Joulescope User Interface (UI) is the quickest and easiest way to get started with your Joulescope. The UI works with Microsoft® Windows®, Apple® macOS®, and Linux®. See the supported platforms.
For more information on the Joulescope UI, see the Joulescope UI User’s Guide.
5.2. Scripts and automation#
Want to go beyond the Joulescope UI? Automate a test? Integrate with a larger test setup? The Joulescope host software is ready to support you. The Joulescope software contains several layers that you can use to integrate. The easiest way to get started is with Python. You can use the original joulescope API or the newer, more powerful joulescope_driver. Both have python bindings. However, the joulescope_driver is a native C application, so you can integrate it with any programming language that can call into a dynamic library.
For more detail, visit the GitHub repositories for each project:
Repo name
Python package name
Description
pyjoulescope_ui
joulescope_ui
The Joulescope User Interface written in QT/PySide6
pyjoulescope
joulescope
The Joulescope Python “driver” with pyjoulescope_driver adapter for JS110 applications. The UI only uses this package to provide JLS v1 read support.
joulescope_driver
pyjoulescope_driver
Native JS220 and JS110 user-space driver with Python and Node.js bindings
jls
pyjls
High performance file storage for Joulescope data
You can find examples of how to use Joulescope in your Python application at:
jetperch/pyjoulescope_examples
jetperch/joulescope_driver
Also see the documentation for pyjoulescope and the Joulescope Driver.
The Joulescope software depends upon other software and libraries. See CREDITS.html for pyjoulescope_ui and pyjoulescope.
